How much lift are you at? (approximately...)They said their all backed up due to no one wanting to work....go figure. They have 9 shafts in line and couldn't tell me where mine was due to "the man" being at lunch. I'm going back over there Monday to get a more definite answer. I didn't think about parts not being available. Might be a factor.
Yes and no on the ride height and pinion angle. Kind of "winging it" on the angles. Engine and trans are at the same angle as before the swap and can lower the trans some if needed. I'm running double cardan joints on front and rear and have shims in the rear. The angles did increase due to the 4 inches of additional length of the trans and adapter. Hoping I can compensate if needed.
Tim
Oops, I see 2.5 SL in your sig line. You will definitely need CV front and rear.
