migs Bronco Barn - a chronicle of what's happening at the new place
migs
migs
First the primer was applied, white in this instance to provide the proper ground coat for the yellow pearl to achieve the desired shade. After that cured and went through the sanding process the yellow pearl base coat was applied and then followed with a few coats of clear.
IMG_7462.jpg IMG_7463.jpg IMG_7464.jpg IMG_7466.jpg IMG_7467.jpg IMG_7468.jpg IMG_7469.jpg IMG_7470.jpg IMG_7477.jpg IMG_7478.jpg IMG_7479.jpg IMG_7480.jpg
migs
migs
And some more after most of the masking is removed. Yellow doesn't photograph well and you don't really notice the pearl without the sunlight. Getting the windshield frame done now should give it a good start to have the paint hardened up nice for when it's time to install the glass. I'm still working on getting the body ready for paint and hopefully will have a stretch of somewhat warmer temps for that larger job.
IMG_7481.jpg IMG_7482.jpg IMG_7483.jpg IMG_7484.jpg IMG_7485.jpg IMG_7486.jpg IMG_7487.jpg IMG_7488.jpg IMG_7489.jpg IMG_7489.jpg IMG_7490.jpg IMG_7491.jpg
tasker
all knowing of nothing
NH
THIS makes this winter weather a little more bearable.....CAN'T wait to see it all in paint! Thanks so much Migs!!!!
migs
migs
Ok, so it's been a rough month winter weather wise this year, almost constant freezing temps and multiple snow storms. Not much Bronco wrenching time, but a lot of seat time in the tractor pushing snow around. Even brought out the big snowblower a couple of times.
There's a thick sheet of ice under all that snow there by that point, not fun....
migs
migs
Finally... although it's not yellow yet, it's nice to see it all one color.😁 The fiberglass and gel coat on that old tub sure ain't the best, lots of pinholes, odd ball checking marks and other imperfections, but the white primer helps show all that I missed that were difficult to see on the dark surface. I'll be able to fix most of that now before the next steps but don't expect it to be perfect, we're not going for show quality here...supposed to just be a quickie paint job.:p
IMG_7637.jpg IMG_7638.jpg IMG_7639.jpg IMG_7640.jpg IMG_7641.jpg IMG_7642.jpg IMG_7643.jpg IMG_7644.jpg IMG_7645.jpg IMG_7646.jpg
migs
migs
Did someone order some yellow pearl?...
Been a busy few days, filling imperfections, more sanding, more primer, more sanding..... Well, before we get to it let's take a look back at this project where it was exactly one year ago today:
And now as of tonight:
IMG_7666.jpg IMG_7667.jpg IMG_7668.jpg IMG_7669.jpg IMG_7670.jpg IMG_7671.jpg IMG_7672.jpg IMG_7674.jpg IMG_7675.jpg
