migs Bronco Barn - a chronicle of what's happening at the new place
904Bronco
San Martin, CA
Agreed....
migs
migs
Been busy cutting and buffing the clear, that's done but I have a couple spots to fix before I roll it out of the booth area to make space to finish painting the other parts.
Here's a comparison of the paint surface before and after the wet sanding and buffing/polishing process.
Also, the sun peeked out today so I opened the door to shine a little sunlight on the pearl.
bronco1017
View attachment 940280 View attachment 940281
View attachment 940282 View attachment 940283
Damn!!!!
tasker
all knowing of nothing
NH
Think the last of the dash trinkets arrived today...cable and lighter
migs
migs
Ok, some quick updates, right around tasker's visit I was working on fixing a few blemishes in the finish. While wet sanding to six the blemishes I ended up going through the yellow in a few spots, oops. Hard to tell in these pics compared to the light reflections but the spots are located in the central area of the pictures.
IMG_7790.jpg IMG_7791.jpg IMG_7792.jpg IMG_7794.jpg IMG_7795.jpg IMG_7796.jpg
And after blending new paint and clear:
migs
migs
And with that done it was on to other tasks. First off I gave my blast cabinet a much needed rehab and tune up.... full clean out, new gloves, consumables, media and viewing glass protector as well as a refresh of the vac system. Also cleaned out the small paint booth and replaced the filter then went on a marathon of disassembling, cleaning, blasting and painting parts. Some things like the power steering pump and hydro boost were just cleaned and touched up a bit as they were in good order when removed.
Still plenty more to go.
IMG_7840.jpg IMG_7841.jpg IMG_7842.jpg IMG_7843.jpg IMG_7846.jpg IMG_7847.jpg IMG_7848.jpg IMG_7849.jpg IMG_7850.jpg IMG_7851.jpg IMG_7852.jpg IMG_7853.jpg
migs
migs
More little bits... So this tub does not have provisions built in for the upper pedal box mounting bolts, it just utilizes bolts through the cowl. Well, the previous builder had just made use of a crude strap, so I figured I'd make something a little thicker and larger to spread the load out.
And if it's going to be sitting there in plain sight might as well give it a little something extra.
Oh, I also made a couple of shims for the water pump pulley to replace the four washers that were being used to space it out.
