migs' build thread - A 1970 Bronco ...an ever evolving project
migs
migs
Well, I fabbed up some new parts for the build.
I had started out with a set of the typical flat bottom heavy duty coil spring cups but had trouble fitting them with my track bar riser and bump stops, so I decided to make my own... with some refinements.
First, I really wanted something heavy duty but to also incorporate the spiral ramp like the factory cups since the coil springs don't have a flat bottom.
I worked the bottom plate up out of 1/4" steel and then went from there.
I kept the overall diameter a little tighter and off set the mounting holes in the same position as the factory cups. I also noticed that on some aftermarket coils the bottom coil does not wrap around as far as the factory coil so I rotated my retaining strap back a bit to ensure positive retainment. and it's all fully tig welded together.
migs
migs
And here in the first picture you can see how the spring wants to lean on a flat bottom cup and then how it sits on my cup in the second picture.
Crawdad
Quit making such cool stuff! It's a shame I have new SS cups wrapped up in storage or I'd be asking for a set of these! Looks great B!
Crawdad
I wonder how affected the ride would be?
Slednut10
Guru? That's funny!
Works of art! (no not you Slednut, the other art with out a capital A) ;D
I know, Pete, I'm a piece of work...............%)
MIGS FABWORKS. Has a nice ring to it. Know a good signmaker?
tasker
all knowing of nothing
NH
stay tuned as Amigzing things are happening!! really came out great Mugs!!
langester
MASTER OF MADNESS
You have some mad fab skills sir, those coil cups are awesome! Just out of curiosity what did you bend those with (unless its a secret)?
Thanks for all the pics of your work too, keep'em coming!
migs
migs
Thanks!
sorry... top secret alien technology:cool:
Ha! actually, just a press brake. but it did take a bit of figuring to get it right.;)
