migs' build thread - A 1970 Bronco ...an ever evolving project
fatboy
Glad to be here.
New Hampshire
It sure was a nice day out today, but I didn't get to work directly on the Bronco.... was busy fabbing up some Bronco parts:p;D
Here's how she currently sits....have to clear the crap off it again%)
Any pictures of said Bronco parts? %)
migs
migs
Here's some. welded up the first complete set of rear shock mounts. made a few changes from the prototype and have a couple minor things to tweek for the process if/when I make more.;)
tasker
all knowing of nothing
NH
get cracking Mugs! MAY will be be here before ya know it!
migs
migs
more steps backwards in order to move forward!;D
Yesterday the engine was pulled with some much appreciated help from Art and his hoist. this was the last major thing to take apart on this build so now I can only move forward from this point.:p
time to get cleaning and reassembling!
migs
migs
Thanks! making headway, I think...
started pulling stuff off the motor today, at least it's keeping up with the theme of bolts coming out easy without breaking... even the exhaust manifold bolts popped right out.
though I am seeing some things that are starting me wondering... like the absence of exhaust manifold gaskets??? they didn't seem to be leaking. I did find a small crack on the end of one manifold as well.
and the oil sure was thick with some pretty good sludge in the bottom of the pan. now the truck did sit for years or decades at a time between brief periods of use, plus we know it spent some time being used in a very sandy dusty environment so that probably didn't help.
migs
migs
so after yesterday's findings I've decided to take it all the way. I'll either fully freshen this one up or consider just dropping in the one out of my 76. I've got time to ponder...
anyone know if ford numbered the connecting rods and their end caps from the factory? I found the one's in this motor already marked 1 through 8.
fatboy
Glad to be here.
New Hampshire
Wow that does surprise me. I know I had all the fluids (except rear differential) changed out when I first picked this up way back when.
Slednut10
Guru? That's funny!
Doesn't look too bad except for the crud in the head passages.
dave67fd
Nothing like tearing into it quick..Keep at it B', she'll be sparkling in no time.:cool:
migs
migs
I thought you had... that goo was definitely circulating into the new oil, the oil filter was very heavy and took like 20 minutes for the oil to start draining out when left upside down!:eek:
A couple other surprises... looks like the motor has already been apart. a quick measure on the cylinder bores shows them at .030 over. and what looks to be dates on the clevite 77 bearings shows 7-85 on the rod bearings and 12-84 on the mains.
I've got it all appart now and loaded up to take to my shop tomorrow where I'll go over and inspect everything better then decide what to build. I kind of have a new plan forming in my head on what I'll build... we shall see.:cool:
migs
migs
Ha! well, I got two sheets of cardboard under there... nothing leaked through.
I bet you've had worse in yours!;D
migs
migs
Got the block stripped down ready to go out to be hot tanked and honed.
also found one of the original freeze plugs left behind inside the block...:-X
