The Explorer lower will NOT fit the 351.
The '93 Cobra had factory 24s on a 5.0
Ford Motorsports had a kit for a long time (probably gone now) that was the MAF, ECM and injectors as a package. Now most people will get a good MAF (not a tuned one as that will be a waste once...) you get a custom chip that will tune the engine to the MAF and injectors and get the timing right as well. Also use it to set idle speed, turn off thermactor and/or EGR and many other tuning aspects that can be dialed in much better then a pre-packaged box.
My 3.25" 330" stroked 5.0 with an explorer intake took 24's. If you have some good heads and turn a fair bit of RPM the 351 could use them as well.
OK, I will look up published numbers for recomended limits on injector sizes...
Published numbers for 19Lb injectors show they are good for about 275 HP (flywheel) on a naturally asperated V8, 24s are good for 345. Just about any good running 351 should be making 300.
Also for fuel pumps a 110Lph is safe for 310 HP and 155 Lph is good for 440 HP.
