mini starter install
mlaird
Houston,TX
probably a stupid 1 but im a novice. finally replaced my 36yr old original starter with the high torque mini starter from JBG. problem is the starter i got has 3 terminals(1 with a wire already attached) and my original starter just had 1 terminal where the starter cable bolted on.
on the mini which terminal should i hook the starter cable to and should i just remove the wire from the other terminal or do i need an extra hookup?
