The diesel ran fine, didn't even check the oil, just added fuel and pulled perfectly - love that truck
Everyone else had fun - Joe's Bronco got beaten like it's never been beaten before and came through ok, incorrect blocks ended up killing a drive shaft slip yolk and joint at the end of the weekend though.
I started tearing the axle down - found some water right away, I'm going to pull the joints apart as well. They still feel perfectly smooth, but they have been in there 3 years and I'm curious.
This motor is toast and needs to be replaced - I am giving Joe my EFI 5.0 stuff as I promised it to him and I'm going to get his complete motor.
Mexican 302, possible cam, 4bbl intake and carb AND the duraspark setup with 3G.
I also have a 1969 351W complete and a set of freshly rebuilt heads, lifters and pushrods - just need a cam. That is another option-
I'm also putting together my final motor at a snail's pace (housebroke) which will be a full roller 95' block based 351W. TFS 185's, Cobra R EFI, 42's, 80MM TB, 70MM MAF, A9L, Pro Billet Distro (with Ford guts) - It should produce just enough HP/TQ to break parts ;D
Either option I go, I'm putting my Hookers and Explorer front serp on the motor and backing it with a NP435 - no more automatics for me.
