carter2772
I need to get some advise on how to time my msd system.
What i have.
-MSD pro billet distributer
- 6AL box
-MSD wires
-351w with 408 stroker kit less that 2500 miles on it
-carborated
So i had this system all dialed in from a local shop that also rebuilt my carb to work well with new rebuild. Recently I had to pull the intake to replace a bad pushrod. I marked the postion of the cap, rotor, and distributer on the block. After putting it all back together i had trouble getting it to sit back down on the right tooth while getting it to go over the oil pump shaft.
Anywho, I had a buddy working on that while i was working on another project. He never really got it right.
The thing is, it runs ok, but not like it should. And sometimes it does not want to idle.
So, today i went to put a timing light on it and couldn't find a mark on the blancer. So, next was to find TDC on #1. Got that, and by doing that i found the mark on the balancer, that said TD with a line. So i take a white paint stick and mark that line so i can see TDC with the timing light...
Put the timing light back on, and now i cant see the line while the motor is running and the light is on. (Yes it is flashing) I know it is supposed to not be on tdc, but using that as a referance, I was going to set it somewhere around 12*...
Next just go for the "time it to sound", but i still want to figure out why i cant see the tdc mark?
Thoughts?
Oh ya, those MSD systems really have a kick to them..... OUCH!
What i have.
- 6AL box
-MSD wires
-carborated
Thoughts?
