- Nov 3, 2003
- 48,964
And I've seen worse upper hose orientations and they still worked. The bends are there, but they're smooth and have a pretty mellow radius.
What I do see however are uncoated headers it looks like?
If so, I would do anything I could to wrap them. I know not everyone likes wraps, but if those are stainless then keeping the heat in with a wrap is not going to be the end of the tubes any time soon. Lots of people run it with good luck.
I know the headers themselves don't necessarily add heat to the coolant. But they can't be helping!
Another thing you can get away with is a higher pressure cap.
The RD radiator has a recommendation, and I'll check to be sure, but I think it's 16psi. AS discussed earlier, the higher pressure merely raises the boiling point of the coolant. Not something in itself that would help you lower the temps. But again, if even a slight amount of the extra temps at slower speeds are due to hot spots inside the block casting, then the higher coolant pressure could indeed help.
I thought you said you had a high-flow water pump already? Flowkooler as well? Is it just painted? Looks different, but maybe it's the angle or the lighting.
What are the pulley measurements again?
