need advice front drum brakes locked
24jedi
Hello,
I have a 1975 stock bronco. The bronco has been sitting for 12 years. I acquired the bronco when my father-in-law passed away, so my history on this vehicle is 'very' limited.
The rear wheels will turn. Both Front wheels will *not* turn...even when the truck was dragged onto a trailer for transporting.
I did notice the brake resevoir is pretty much bone dry. I am hoping it is as simple as adding some brake fluid and bleeding the brakes.
The only other thing I can think of is to remove the front drum brakes...which I was planning to do anyway..
I know that, since the vehicle has sat for 12 years, I've got lots more to do, but am starting on the brakes first, so I can move it into my garage.
Any advice would be much appreciated. Thanks in advance.
back the adjusters way down on the front brakes. drag it around a little more and try to get them to turn. you really need the wheels to free up in order to take it apart and fix things.
Also, remove the front wheel lockouts and look inside. If they are full of rust then someone ran it through deep water (with bad seals) then parked it. The bearings could be a solid block of rust.
There is a Ford oddity about Bronco front drum brakes. They are pressed onto the wheel studs with the hub. Unless someone has modified it (or it got damaged), in order to get the drums off you have to undo the wheelbearings and take the drum and hub off together. Do not expect the drum to slide off the hub (like the rear brakes do).
I suspect there will be lots of bad parts involved and disk brakes will be a good upgrade/repair.
24jedi
Update:
I tried to back off the adjuster with no luck. They wouldn't budge. Ultimately, I had to remove hubs,bearings,..etc.. then beat the crap out of the drum to get it off. The shoes were rusted to the drums and all internal parts rusted as well. It took some time just to pry the drum off, even after the removing all parts.
Looks like I'll be investing in a new brake system after all.
