mnido
- Joined
- Jul 20, 2007
- Messages
- 993
I have done a couple of searches for brake issues after installing a TOMS Chevy front disc brake conversion with a TOM’s booster, proportioning valve, new rear brakes and hardware, all new stainless steel brake lines and have not been successful in finding out why I can’t seem to get good braking power. I bench bleed the master, and bleed a gallon of fluid through the system. The master cylinder is correct the large reservoir in gong to the front, the smaller to the rear. I have ground for good clearance on the front calipers, bleeders are facing up. I have good vacuum to the booster, running 35’s. The braking is sketchy. I have read several posts that agree this is a good system and TOMS has been very good to me, but in a panic situation I am not comfortable. Anyone had a similar issue?
