Some Broncos sat high in the rear right from the factory.
Some Broncos have sagging front springs that let the rear sit high.
Some Broncos have aftermarket modifications to the rear (add-a-leaf, block, spring pack) that end up with the rear sitting high.
No Bronco came stock with rear blocks under the leaf springs until '78 and later full-size Broncos came along.
As was said, some more info would be great.
And while you're at it, you can measure a common point that was determined years ago to be very helpful in diagnosing and determining what height the suspension is sitting at currently.
Measure between the bottom of the frame rail and the top of the axle tubes, front and back, and see what you come up with.
Stock was "approximately" 7" in the front and 6" in the rear. Anything above or below that is lift or sag.
They are suspiciously approximate though, because not ever Bronco came the same way from the factory. The body style, suspension options, exterior options and added accessories, all can have an effect, no matter how slight, on the ride height.
But measuring will get you close enough to help.
