Recently finished an EFI conversion. Engine was turning over but not starting...determined I had a fuel pressure issue. Got the fuel pressure issue resolved. After fixing the fuel pressure, the engine was still turning over but not firing. With key in the "ON" position, probed red coil wire and it was fine. Probed green coil wire and it was fine. However, it was after I probed the green coil wire that the engine was no longer turning over. Fuel pumps still kick on when key is "ON", however when I turn the key to "START"...dead silence. Not sure what changed after probing that green coil wire.
Battery has a full charge. I have a brand new starter solenoid. Starter checked out fine when tested at NAPA this morning. I have a good ground to the EFI harness. No blown fuses. Not sure where else to turn. Help please.
