DebosDave'72
Hello everyone,
I am looking for some advice on how deep down the rabbit hole to go, and how much to temper my expectations on every getting my money back on my project. Now I definitely understand the old adage "you rebuild for love, not for return" and I fully expect to get those types of responses. I would however also appreciate some thought and input to the "how far" "too much" "not enough" aspect of restoration as it pertains to financial return. Ok, here is my story and question:
I purchased a 1977 bronco in Montana roughly 2 years ago. According to the add, it has an NP435 transmission, lockers, and on and on. I drove around 2 hours to go "look" at this bronco, and brought my car hauler along "in case". I ended up purchasing the bronco without driving it for $12,000. My mistake without question, I was fueled by the increased demand along with the extreme lack of local supply. Fast forward, and what it appears I actually have: I was told it had a detroit in the back, however it is locked all the time, tight turns at any speed and you can feel it fighting. The transmission has the syncros completely gone, you need to float gears to shift, and throttle control to downshift. The clutch must work to some extent because it starts with the clutch like normal. Also, 1st gear isn't super low, infact you can't really start successfully in 2nd gear as it seems too high. Not sure what the transmission is. On to the body. The front gas tank appeared to have been bondo'd over and when I got it home I attempted to chisel the bondo from around the fuel door. To my surprise it wasn't bondo, but the opening was closed up with fiberglass. The floors have been "patched" and covered in a layer of fiberglass as well. Significant rust in typical places and more. The body seems "solid" but needs a lot of attention. 3" body lift, and what I am assuming is the original suspension. Windshield frame and door pillars aren't aligned perfectly, something must have been changed, but not perfectly...
I have had the bronco for sale off and on for the last 2 years, and have gone down to asking $9900. I turned down an offer for $9000 at the end of summer. My reasoning is that if I am going to lose that kind of money, I might as well keep it because it will be very difficult to find another when I am ready again in the future.
I just drove 2400 miles in 38 hours to pick up an AX-15 and adapter kit to install to make the bronco more driveable.
On the drive home, I am going back and forth questioning if I am going to do the work to put in a new transmission, what else do I do at the same time. And how far can I go before I really start to lose money on a resell if that ever becomes more of a necessity. Also, is there even a chance I can go only so deep and actually help myself recoup some of the money that I am already down??
So here is the question: In your opinion, do you feel like there is a way to repair this thing enough to gain back all past and future investment? What matters the most in resale? Should I repair and make nice the interior and body? Should I do more than replace the transmission on the drive train? A total frame off?
If I replace the transmission, and maybe lower the 3" body lift, put a 1" body and freshen the factory suspension, then put around $25,000 into the body and interior, is this thing going to bring $40,000 plus to recoup my money??
Thank you in advance for taking the time to read this, and I really value the opinions of those of you out there with some experience. This question is most strictly for a financial perspective, however if I fix it up I will inevitably enjoy driving it around before I would sell it...
Let the discussion begin!
