BroncKrawler
I've removed both axle shafts, rear drive shaft, all the bolts and copper washers from the third member. I've hit it with a dead blow every way imaginable, installed the u-joint bolts and slide a pipe in there to try and pry it out from the yoke, so far nothing has worked to budge this thing. What are some tips / tricks that I could try to help me remove the third member?
