@LittleBeefy thanks for putting into geeky engineering speak what I have theorized about and supports my theories. Makes me feel less crazy
Thatās called confirmation bias! (geeky engineering speak).@LittleBeefy thanks for putting into geeky engineering speak what I have theorized about and supports my theories. Makes me feel less crazy![]()
I am sure that is an expensive kit, the owner and I chat about it. I dislike wilwood, so I would rather not use their products.Got a link? I don't see that on their site. That must be a pretty expensive kit.
Bachelors and Masters in engineering from Georgia Tech. Geeky Engineering is my second language! I plan to have āWork = Force x Distanceā put on my gravestone hahaha. Happy to help.@LittleBeefy thanks for putting into geeky engineering speak what I have theorized about and supports my theories. Makes me feel less crazy![]()
That splains thatBachelors and Masters in engineering from Georgia Tech. Geeky Engineering is my second language! I plan to have āWork = Force x Distanceā put on my gravestone hahaha. Happy to help.
I am now very confused. 1 5/16ā is an enormous bore. Thatās what you would find on a 97 Suoer Duty which has dual 60mm pistons at all 4 wheels and hydro boost assist. Why do you need an MC with such a massive bore? What calipers are you running? Stock is 2 7/8ā so 2ā seems undersized. What rotors are you running that are so thick?That splains that
In the EB world we need a plastic reservoir master with a 1-5/16 bore that is the same height as a corvette style master. Many of us are running large enough calipers that we need this much master cylinder to push enough fluid for a good pedal travel ratio. Actually, would be happy with a corvette style master, just never seen one with a large enough bore. The issue some of us have is the only thing we've found that is close to fitting under the hood is for a 85 chevy K30. it works but mine hits the hood and they are terrible about the lids leaking. I have nowhere to move the master to, it is a special build that everything is close to everything LOL. we also need a 2" bore caliper that fits a 1.295" thick rotor for better bias. I also understand that this stuff is what you do for a living, not expecting you to give out info for free, I'm one of the few shop owners that gives virtually everything away LOL.
Need is a funny word.I am now very confused. 1 5/16ā is an enormous bore. Thatās what you would find on a 97 Suoer Duty which has dual 60mm pistons at all 4 wheels and hydro boost assist. Why do you need an MC with such a massive bore? What calipers are you running? Stock is 2 7/8ā so 2ā seems undersized. What rotors are you running that are so thick?
That makes sense now. Have you considered switch out your pedal assembly for one with a lower ratio?Need is a funny word.
Nobody needs a 1-5/16 master cylinder in a 3800 lb car.
The problem is that the pedal ratio in the original Bronco was designed for manual drum brakes. Brake evolution over time has maintained that same pedal ratio. When you add Hydroboost to the original pedal geometry, you end up short-stroking the hydroboost input. In order to reduce pedal travel to approximate a "normal" movement, you "need" to oversize the master cylinder piston.
Every once in a while, someone will try to run the factory K30 caliper when they do a Dana 60 axle swap, and it ends up with a 3.368 diameter bore caliper. Those pistons displace a lot of fluid, and the factory K30 master cylinder bore is 1.31 inch. I think that @Yeller plays with the big stuff...
I don't know of anyone that does that except one of the hydro kits that mounts to the stock-type angled booster is probably in that range (it's been years since I've measured anything on those brackets so I don't remember what they change the ratio to). Tom's h-boost bracket might change the ratio as well too. I did one conversion on a buddy's truck years ago with the stock angled bracket and as I recall, it had a real good pedal feel when I was done (Ford discs in front, Eldorado's out back and a 1.125" Corvette master iirc).Is there anybody that makes a revised pedal geometry for hydros application with something closer to 4:1?
Seems like it would be a fairly easy conversion, no?
I think brake bias really matters on an early Bronco. Especially when lifted. Short wheelbase, high CG. Under a hard brake stop (if you have the tires and front brakes that can take it), and a bit of a lift, light back end and an heavy nose. You could just about stand it on its nose.curious how much brake bias matters with these early broncos and if any of the existing BBKs have calcs to share?
Iām running a Duff bracket. Iāve looked at removing it and moving the assembly outboard further to clear the valve cover but then it hits the alternator. Iāve contemplated going to a 3.5ā spring from the 5.5ā spring so I can lower my spring tower so I can lower the master cylinder a 1/2ā so it stops getting friendly with the hood. I built everything with manual brakes, which is part of the closeness issue.You don't have the stock Bronco power brake bracket, do you, @Yeller? That reduces the stock manual 6:1 pedal ratio a bit.
Todd Z.
@LittleBeefy , @jamesroney is correct, I play with the big stuff. GM single piston calipers for an 85 k30 on a yesā¦. GM 60, pumpkin on the wrong side and all. No hydroboost, 9ā vacuum booster. Brakes are great, pedal travel is good and stops well. The rear rotors are front 85 K20 front rotors, with currently 2-3/4 bore GM calipers. Bias is horrible, manual valve is closed as much as it will go and barely sufficient, needs a smaller caliper. The master rubbing on the hood is annoying too
My signature doesnāt lie, I tend to ride the short bus lol. And if you want a different kind of build thread read, itās in my signature as well, itās just a well disguised buggy that does wear most of a bronco tub![]()
Having not messed around with the 80-86 trucks, like your 84, much at all - what kind of pedal ratio do they have?The problem you have is a combination of factors and so there are different ways to solve it. First, you have far too much mechanical advantage in the pedal so you are making up for it by reducing the hydraulic advantage in the MC (Iām sure you know that). That creates the second problem which is that you are needing a a bore size in your MC that is generally reserved for hydroboost based systems, but you are using a vacuum booster. Itās virtually impossible to find any MC with a bore that large that fits a vacuum booster. Consider a couple of options. First you can reduce your mechanical advantage with a pedal kit designed with lower ratio. Second, you could look for a booster mount that will reduce mechanical advantage of the pedal on the MC. Third, you can switch to an Astro boost setup which will give you significantly more options in MC.
Or you could use the MC from a 1983 Corvette. After cracking out on an MC search last night for a few hours I couldnāt find another MC like what you are looking for.
I haven't looked at the factory power brake booster bracket lately, but from memory, I don't remember much of a difference in the linkage lengths in it, and thought all of the pedal ratio was set inside the truck at the pedal.I don't know of anyone that does that except one of the hydro kits that mounts to the stock-type angled booster is probably in that range (it's been years since I've measured anything on those brackets so I don't remember what they change the ratio to). Tom's h-boost bracket might change the ratio as well too. I did one conversion on a buddy's truck years ago with the stock angled bracket and as I recall, it had a real good pedal feel when I was done (Ford discs in front, Eldorado's out back and a 1.125" Corvette master iirc).
Within the last year or so, I bumped my master cylinder up to a 1.25" Dodge unit after 20+ years of running a 1.125" Dodge unit (various brake caliper configurations - all 4 wheel disc) and the pedal feel is much better. Much less touchy, better pedal height, less pedal travel, and firmer pedal at the bottom of the travel, and feels more like an OEM installation (my '01 Super Duty as a baseline for pedal feel).
Todd Z.
I donāt have the stock pedal ratio (or the stock pedal for that matter). I switched to hydroboost and installed a brake pedal from a 1997 SD to reduce my pedal ratio. The are interchangeable on the bracket (just hard to find).Having not messed around with the 80-86 trucks, like your 84, much at all - what kind of pedal ratio do they have?
Todd Z.
Does anybody have better data then my crappy memory?
You aware of somebody who sells one by chance?
Like this one?![]()
Don't forget that the bias ratio goes with the square of the piston diameter. So your 3.368 front pistons have 8.9 square inches of piston area. Your rear calipers have 2-3/4 pistons with 5.93 square inches of area. (that's 66% bigger) Typical D60 (1 ton) front rotors are 12-7/8 diameter, and the 3/4 ton GM fronts (adapted for use on the rear) are 12-1/2. Most people think that the 1 ton GM brakes are a lot bigger than the 3/4 ton stuff. But it's really not. It's just a lot heavier. They had to stay relatively small diameter to fit under the 16 inch wheel. Braking force acts linear with rotor diameter, and that contributes another 3% difference. (and yes, I know it's really an (r cross F) vector.)Iām running a Duff bracket. Iāve looked at removing it and moving the assembly outboard further to clear the valve cover but then it hits the alternator. Iāve contemplated going to a 3.5ā spring from the 5.5ā spring so I can lower my spring tower so I can lower the master cylinder a 1/2ā so it stops getting friendly with the hood. I built everything with manual brakes, which is part of the closeness issue.
As for rear brakes. Iāve looked for a thinner rotor to run metric calipers, with no luck. Iāve considered turning them down far enough to fit the calipers but am concerned about warping, taking nearly .200ā off is a lot, well past minimum spec.
Truck drives great, but I notice the bias valve being almost closed, it makes the rear brakes slow to react, most would never notice, highway speeds is where it becomes really evident, hold steady pressure and the braking increases as you slow down.
