No brake lights but hazzard lights work
tampabronco
Any suggestions on where to start? Rear lights work and lights blink with hazzard switch but no brake lights when pedal is pushed. I did a quick check for loose grounds but no luck.
Viperwolf1
electron whisperer
Check brake light switch. 12V in and 12V out when pedal is pressed. If that's good the turn signal switch is bad.
tampabronco
tampabronco
Should have mentioned I have new turn signal switch
driving me nuts trying to find
No more complaining allowed until you check your brake pedal switch.
You have a new turn signal switch you say, does the installation of this switch happen to be the same time the brake lights quit working?
