thelakerat
- Mar 15, 2005
- 9
The box looks like a 99-04 Jeep Grand Cherokee to me. I have several if you need one. The wad of stuff on top was to try and make the adjuster stop leaking. I have new caps and new sealing lock nuts if you want one.
As for that broken tap, a cutting torch right through the middle of it and the 4 sides will just fall in. If you don't have a torch just use a small punch with quick sharp hits with a hammer to break it apart and then re-tap it.
As for that track bar, Several of the other posts have already said it but it needs to be at the same angle as the drag link to reduce bump steer. so either drop it off the frame mount with a bracket of raise it off the axle with a new mount. they just need to be parallel. It doesn't matter how close they are to each other just parallel.
