pcf_mark
- Jun 11, 2010
- 3,594
Fellas - my 4R70W conversion is essentially finished but today I was looking at the front driveshaft and things look - TIGHT.
I have Ford auto column with modified linkage going down to the 4R70W. I have modified the lever on the transmission (cut and re-positioned) so the lever is basically horizontal but I can change gears nice and smooth and it is as high up as I can get it.
RIGHT next to it is the Hedman header ball socket flange. I can move the bolts around to maximize room but it is still hitting the old driveshaft when i mock it up. I may be able to bend the headers for a little more clearance but not a lot.
This is a street and snow rig only no off roading. If I can start with a decent fit that needs to be shortened that would save some coin. Explorer? Cherokee? NP205 has me confused on my options.
Questions:
1) What type of u-joint does the dana 30 on the front use and how can I confirm that? My front diff has king pins so i am pretty sure it is D30
2) The NP205 uses a cardion joint correct? I did not get a driveshaft with the NP205. I assume I should replace it with another cardion type.
3) Can I get a strong but skinny driveshaft in the area it is tight? The lower portion of my existing driveshaft fits right through there
Thanks guys!
Questions:
Thanks guys!
