Nv3550
dondolittle2
Ringgold
I am new to Broncos and trying to decide which way to go, I want a road worthy vehicle with decent mileage. I have a NV3550 tranny I got with the trade. Presently it has a 3sp on column What adaptors will I need to install and is it worth it. BTW I would like to turn round 2000-2200 rpm at 70 mph since this will be a daily driver
moses_m
Most of the vendors sell a kit. Toms has a 5 or 6 part video on install on youtube which helped me. If you dont have a body lift some rail cutting may be necessary. Good luck
bigpitbull
BRONCO ADDICT
Saltillo, MS
Dondo
Do not worry about asking questions. That's what the forum is for. The search option is a good tool but at times I still can't find the answer so I post a question. As stated earlier the vendors sell a kit. Check with them. From what I have read its a pretty simple swap. One that I have considered for my current 73. Good luck and let us know if you need anything!
Pops68
Bronco Rookie
Bazetta Township
I did the swap last year from a floor mount 3 speed to the NV3550. The article mentioned early on (by MARS Chariot) really helped. I got my adapter kit from Wildhorses along with the appropriate twin stick kit for the transfer case. Basically a 2 day job for me, as my father-in-law has a lift and about every tool imaginable plus alot of knowledge. I read and re-read every article I could find prior to tackling this and gave the instructions to my father-in-law prior to starting. We had a few issues, but all worked out - I have no body lift, so it was a tight fit, but I cut the tunnel bigger than probably necessary and made a removable service cover.
I would do it again if I ever had to.
Rides nice, too!!!
Pops
Timmy390
Conway, AR
I am new to Broncos. BTW I would like to turn round 2000-2200 rpm at 70 mph since this will be a daily driver
The classic bronco is a brick and is hard to push down the road at 70 without more RPM. That low of RPM it will bog down on any type of incline with stock 3.50 gears and you'll be shifting in and out of OD so much you will not even want to use it...JMO
Don't be afraid of RPM. 302's LOVE RPM's and run their best higher up.
Lots of guys here running NV3550's and I hope to be one soon. most run at least 4.11's.
Tim
Hey dondo, welcome to ClassicBroncos! Good to have another new EB owner.
If you'll forgive my laughing slightly at your expense for a minute though, I had to chime in about the "road worthy" and "decent mileage" and the "2000 rpm at 70" comments!
Just messing with you. It can be done of course, as we were just discussing a couple of days ago. Can't remember who it was exactly at the moment (00gyrhed maybe?), but that's right where his engine runs and he's loving life with his overdrive.
And the engine is going to be the key here. What are you going to be running in yours by the way? Most standard EB engines will likely hate running (lugging?) at 2-grand while trying to push 4500 lbs of rolling turbulence through the air. Even on flat ground with a tail wind!
However, if your engine is finely tuned and running strong in that rpm range, you could be on to something.
But let us know what other mods you have in store. What size tires for instance? What gear ratio does it have now, and what are you thinking of running? What (if any) amount of lift and will it be cut or uncut?
Any other mods?
Mostly curious, and I do usually try to be helpful :p, but I figured I'd get the potential stumbling blocks out in the open right up front. After all, these are not modern vehicles. And we don't know whether you're used to that or not. Many of the new EB owners are coming from a typical background of newer, more road-worth rigs. As opposed to the old days, when it might have been a rancher's son grabbing his dad's Bronco to make it more utilitarian and/or hunting trail worthy.
Hope to see more of your rig. Got any pics you can post up to an online hosting site?
D
dondolittle2
Ringgold
My tires are BF Goodrich 33/12.50/15
On the rear chunk It says WRF83 784
L509 695F
the best I can read it laying underneath on the ground in the dark at 34 degrees
Does that mean any thing to anybody?
bobscott
You can count the number of revolutions of the drive shaft to get an approximate on your rear end ratio. Rotate the wheel and get someone to count the drive shaft revolutions.
blubuckaroo
Grease Monkey
Ridgefield WA
I have to disagree with having to have a high revving 302. Mine is pretty well built but any Edelbrock cam and 2bbl carb should do pretty much the same. I just dragged my 2500 lb + trailer from SOCAL to WA with what you see on my specs. I actually pulled it in 5th most of the time. A pretty much uneventful trip. A 302 can be built for torque. It's easy too. Just quit listening to all the nonsense.
moosebob
Don,
Welcome to the site.
I put a NV3350 in my '69 and I love it!
I also fabbed up a removable service cover and had it LINE-X coated to match my tub.
I run the same BFG tires, and went with 4:11 gearing.
I WISH I had dropped a pair and gone 4:56
Honestly, I dont like to run the thing at 70mph, too short and twitchy for my tastes.
That being said, I rarely use 5th gear. That is why i honestly feel the 4:56 would have better all around.
PS: put in a 1" WildHorses body lift. it makes the install SO much easier.
33s, 70MPH, 302, I am going to call for about 2400 RPM as a better target RPM. 2200RPM would require a 302 that was near magical and even a 351 wouldn't be happy pushing that much wind and rolling drag at 2000 RPM. 70MPH you are pushing a lot of wind. I could really feel the drag pulling after about 60. Run as little lift as possible. Lift just adds drag at speed. 33s can fit without any lift. For 70MPH cruising speed, I would add 100 RPM for every inch of lift.
If the gearing split puts you at 2300 or 2500, I would take the 2500. Carbed 302s do like a bit of RPM at cruising speed. Forget what you may know about fox body mustangs idling down the highway. The drag difference does not allow them to be compared.
Plenty of online gear/speed/RPM calculators that you can punch numbers into and play around with.
If you are not convinced once you decide on a ratio, start with just the rear axle. The 9" is a pretty easy diff to set up. you can put a gear in there and take it for a test drive. If it isn't right, try the next one. After you are sure you like the gearing, then drop the coin on the front to match. No point in gearing the front to match the rear then take it for a drive and find you don't like it.
L509 695F
Those numbers don't speak to me, but someone may know how to interpret them. Are they from a metal tag under one of the nuts? Or cast into the housing?
The one string "L509" is close to what you see a lot on the tags, which would be "3L50" and would mean you have a 3.50 to 1 ratio gear set with a limited-slip differential.
But that's not how yours is stamped, so I don't know if it means anything or not.
Could there be a "3" lost under the nut, or gouged out to the point you can't see it? I wonder...
And blubuckaroo is another of the ones I was thinking of, with a good setup that lets his engine run happy at a slightly lower rpm range. But based on his description, I don't think he's down in the 2000 rpm range at 70 either. I would think he's more in the 2500 rpm range at least. I could be off though, and he can confirm or deny that bit. :)
His is actually near what I was describing earlier. With slightly more modest 32" tires and 4.11 gears with "only" a 3" total lift. Plus some key engine modifications, his is set up to run well and strong in the mid-range
Engine specs are good for that range it looks like: - 302 Windsor Jr (heads?) w/4bbl & headers, NV3550, 4.11s, rear Yukon posi -
His should run circles around any stock EB engine in my experience.
So based on your tire size and NV3550 then, I'd say to at least take into account what moosebob said and consider the 4.56. The larger tires have an amazing difference in performance considering the minimal size change. You're adding size AND weight, which I've always felt was under compensated for.
As I said in another thread though, I'm going to stick with my 4.11's when I do the same swap as you (also with 33's, but a different brand) and will know more from personal experience then.
But that's down the road a ways still, so until I do my own and live with it for awhile, I have to base any recommendations on what others here have said.
Including buckaroo and moose and 00 and others. Seems to be a range of happiness between the 4.11 and 4.88 ratios. But fairly universal that you can't very well use an overdrive trans with 3.50 gears. So like was said, check yours with one of the spin-the-tire methods.
Good luck.
Unknown
I opted for the AX15 5sp and went 456 gears with 10.50 x 33's. One of the best upgrades I've done. My speedo is about 4 mph off so at approx 70 mph I'm seeing around 2500 rpm.
kntr
I plan on running a 407 stroker and a nv3550 with 35" tires.
What would be the ideal gear for me?
BoureeOne
Madisonville, La
Dondo
I have to agree with Pitbull here. Sometimes it is difficult for new people to find exactly what they are looking for. We have all been there. Never stop asking questions. The ones who want to help, who want to see you do it right, will respond and do anything they can to help. I too am doing an NV3550 install. I cannot read enough about it to help me feel I am doing it correctly. My advice would be for those who seem to get tired of seeing the same questions or topics. If you see a thread title that you think you have read before, and you don't want to read about it again, then don't open it.....
Probably one with teeth on it;D
Again, too little info. No idea where you custom engine will make (and not make) power. No idea how you will be driving it. I question the choice of a NV3550 on a big inch stroker. So my suggestion for an ideal gear for you is simply one that has teeth on it. Without teeth on the gear it isn't going to go anywhere.
It may be better to start a new thread about your exact combination instead of muddying up this one, which can get very confusing for the original poster to pick out the info that pertains to him and the information that would pertain to you. So by hijacking this thread you just made it a confusing mess that usually results in horrible information to everyone.
blubuckaroo
Grease Monkey
Ridgefield WA
Good luck.
Paul, you've described my car's drive train pretty well. I'd be the first to admit that you need good torque to drive at this RPM. My choice to switch to 4.11 gears came from a need for power to tow my camp trailer. It handled the trailer nicely but now I had to listen to a screaming motor when going over 60. That's when I decided on the NV3550. Yes it works well but I don't plan to go over 32" in tire size either. If I did go to 33", I think a 4.30 ratio would be more appropriate and probably 4.56 for 35" tires.
One other characteristic of the NV3550 is its low 1st gear. It's not a granny gear but it's pretty low. If you get your differential ratio too low, the first gear may be pretty much useless for normal driving.
