Odd steering problem
BROwN COw
I noticed driving home from the Carolina Broncos event that my non power steering set up on the 1970 had a "hump" that I had to push through to keep the wheels centered. Both directions. It was quite tiring (more so than normal as tiny corrections back and forth were constant to "keep 'er between the ditches". I drove that sucker 3.5 hours home last night.
Justafordguy
Sounds like the steering gear is binding up. You better check that closely before you drive it any more.;)
BROwN COw
BROwN COw
Yeah, it was spooky. I'm already getting passed by grannies on the interstate as I dare not go faster than 60.
brewchief
Check your front axle u-joints, I've had them seize up and make the steering kinda like what you describe even with power steering.
All of the above. Could be a number of things, but if you messed with anything recently that would be a good place to start.
Aftermarket steering links, or stock? Either way, make sure the adjusting sleeve clamps are not rotated in such a way that they could catch on something. Such as the lower trackbar bolt or double-shock lower mount, etc.
Ball joints could have failed, like brewchief was saying about the u-joints. Or they could both be on their way out.
Even wheel bearings or brakes dragging might not sound like they'd have similar symptoms, but if one is dragging it's putting some strange inputs into the steering. More often that feels like a "pull" one way or the other, but you never know.
And like said, of course it could be the box. If some debris is broken off from the inside, or the gears are worn out, or someone tightened up the preload adjuster on the top of the box, it could bind in the on-center position.
Sounds like it's time for a full inspection. Right from the steering shaft joint(s) on down to the ball joints, with everything else in-between.
Good luck. Let us know what it turns out to be.
Oh, and check the air pressure in your tires! With most modern truck tires, you could have a total flat and not even know it except for how it steers.
BROwN COw
BROwN COw
Paul, Cheif, and Justa- thanks for taking the time to provide input. I'll let you know as my plan is to drive it from Charleston, SC to Super Celebration.
jdbronco
Panama City Beach
My worn out manual box felt like that in the center too. Messing with the "adjusting screw" as people call it, would change how much resistance I felt but since it was so worn out I just switched it all to power. :)
