Ohms for testing Aux 12 gal Sending unit
RedLeg0811
Maltby, WA
I am wondering if anyone know what the ohm readings are supposed to be so I can test the sending unit with an ohm meter?
Yes I know I can plug it in, but I am not ready to do that with the other work I am doing and I need to get the Aux tank in before I can complete that work. Chicken or egg, right.
Martin
MarsChariot
Planetary Offroader
Albuquerque, New Mexico
I don't think that I have done this on an aux sned yet, but here are results for the main sender. The idea was a comparison of the typical aftermarket sender with the OEM sender. But results for the aux should be similar to the main over its range of travel.
RedLeg0811
RedLeg0811
Maltby, WA
I get 82 ohms empty and 11.5 ohms full. I think there is a 10ohms +- variance allowed. Maybe 30 ohms at approx. 1/2
Also have a chip in the float I want your opinion on. Will post picture Thursday
RedLeg0811
RedLeg0811
Maltby, WA
Found out I need to either replace the float or repair it. If I don't the foam will soak up water and fuel. I can't find a replacement unless replacing the whole sending unit, so maybe a bit of JB weld.
I had to "tweak" my factory original sending units AND my dealer sourced brand new ones back in the late seventies.
I bent the arms in such a way as to catch the stop bars earlier or later, and even bent the bars a little bit too if I remember.
Mine never read full in it's life, and always empty was WAY below empty. I always ran my tanks dry back then (before I knew I was stressing the fuel pump) so knew just how much I had and how much I needed.
When I was through with my bending things, the gauge read perfectly for me. Just a needle's width or two above the line when full, then just the same amount below the Empty line when I ran out.
All in the adjustments to match my own gauge and electrical system characteristications.;D
So if you get a new one that doesn't quite match up the way you want, don't hesitate to make a few modifications yourself before installing it.
The extra time now is so well worth it.
RedLeg0811
RedLeg0811
Maltby, WA
Thanks Steve, but wrong type. I found those type all over. The type I have I found, but only on a whole sending unit.
Paul,
I know about the bending to tune it. I was just trying to do some preemptive work before mounting the tank.
Martin
Aftermarket tank then it looks like. Definitely a more finicky setup, at least in the main rear tanks. Not sure about the front tanks.
What brand tank are you installing?
