Oil leaks from dipstick
wesleydax
What causes oil to be pushed up and out if the dipstick. It just started doing it the ither day. Could the pcv have gone bad over night? I can take it out of the valve cover and theres a fine smoke vapor coming from the valve cover and it causes no change in engine performance or idle. But with the pcv out it will not push oil out.
G's Baja Bronco
Sunny SO CAL
if you have smoke vapor coming out of the PVC hole, I hate to say but sounds like blow-by! how many miles on the engine? do a compression check!
wesleydax
wesleydax
Im guessing around 10k but it was built in 89. Still cranks and runs great and doesnt use any oil.
wesleydax
wesleydax
Does it matter what pcv i have? I used one from a 68 mopar 383block and the cap from the other valve cover. I looked on Advance auto web site and it shows different part numbers. Aren't they all the same?
wesleydax
wesleydax
ok been checking so things and i think i have the wrong pcv and wrong oil fill cap. the cap has a pcv also. so im not sure but im thinking that could screw things up. im going in the morning and get a new valve and breather cap.
COBlu77
Arvada, CO
Try the correct PCV valve(s) first. They are different. If that doesn't fix it, do a compression check. It might blow-by, but hopefully not.
