Oil pressure fluctuations
Yooper74
I've got a 74 with a 302. New dakota digital gauge package with dakota oil pressure sensor. This weekend while cruising around the oil pressure started fluctuating. it would go from 60 psi, drift down to 20, back up to 40, then down to 0 and back up to 60. It was all over the place with no rhyme or reason. Not tied to RPM or anything. Engine sounds great. no ticks, squeaks, pings, knock's or rattles.
This was the first weekend I got any real driving in after restoring it over the winter. I have not prior history with vehicle.
gick70
Sensor probably sucks eggs,like everything new junk,bought old stock sender,all good,quality sucks.
I would Tee in a mechanical oil pressure gauge and run it again. If the mechanical gauge is doing what the electrical gauge is doing, you have an issue in the engine. Or as suspected, a sensor issue.
armynavy17
I'm sure you've already checked, but what's your oil level at? After the engine and filter is pressed up the sump level will drop some. How flat was where you were driving? Could the oil pump be losing suction?
Y
Yooper74
flat ground driving. It even fluctuated in the garage while idling at one point. but not consistently. pretty random
It is a fresh oil change and I verified level
Master Chief
I see you did a winter restoration. Did you do anything with the engine? In addition to teeing in a mechanical indicator as Bowsher mentioned, I would pull the current sending unit and see if you have any debris in the extension tube.
Another thought is to make sure the new gauge is properly grounded and that it is compatible with the sending unit.
Y
Yooper74
I didn't do anything to the engine. i believe it has been rebuilt at some point prior to me picking it up. Unfortunately do not have the details on it.
I thought about the extension tube debris possibility i may pop the Dakota sender off tomorrow and check that
gr8scott
You might call Dakota too, just to see if there are any quick checks to isolate the issue and determine that it's NOT the gauge, controller or sending unit having the issue.
Since there is wiring involved, I would check that first though. A loose connection or bad solder/crimp junction can give all kinds of fits.
Get rid of the fram filter use a Napa gold, Wix, ford FL 1 or a K&N filter.
73azbronco
I have Dakota and while I don't have oil pressure flux I do have other random fluctuations. I thinks it's a ground issue. Not my ground but something inside the dakota box and chincy way you attach the wiring with small screw in set screws. One of mine had plastic flashover inside screw barrel so it never made contact, that took a few months to figure out. If you call Dakota they will say it's your ground issues, not theirs... One of very few regrets, if I had to do it over, I'd stay stock dash.
Y
Yooper74
I do have a NAPA filter. How would that cause fluctuations? Plugging up or something?
When It does move its slow. Not on and off or anything like that. Would think if it was a ground issue it'd short to 0 and move fast. Maybe??
bummer to hear that about the dakota. i've never heard anything bad about them
pcf_mark
Put a mechanical gauge on it to verify. Dakota is not so great on the quality front.
Eoth
Had that problem once... Turned out to be a bad/intermittent connection on the oil sending unit. I cut off the end of the wire and crimped a new connection on it and all was good in the world.
The cheap filters have a cheap poorly designed bypass valve to save money. bypass valve is designed to prevent oil drain back and to bypass the filter if the filter gets plugged up.
