I’ve seen this question many times in prior threads but haven’t seen an answer so I’m throwing it out there again. I broke my old oil pressure sending unit extender off in the block (yay.) so I’m replacing it with the aftermarket extender you see at all the usual suspect sites. It’s got the 45-deg angle at the end to make access easier for the sending unit. When I turn it into the block, it tightens up by hand with the angled end pointing up, like you’d need to install the sending unit. But if I tighten down the extender further with a wrench, the angled end would be pointing toward the oil filter or even further down. Any ideas for getting the extender tight into the block, with the angled end pointed where you need it? I’m afraid of trying to get another full turn out of it and breaking this one off too! Hope this makes sense? Thanks all! (74 Ranger, 302)
