[quote author=DesertRat302 link=board=5;threadid=12861;start=0#96625 date=1041548090]<br>Yes,it's the right size for an EB,I have one in mine.<br>770 CCA I believe.The dual terminals are nice,makes hooking up accessories and jumpstarting really easy.<br>I happen to work for Costco,and we also carry the yellow and blue tops.(At least at my location.)<br>In the year and a half we've carried them,I've never seen one returned.But if for some reason you do have to return it,during the first 2 years replacement is FREE.<br>No pro-rating like the parts stores.<br>At least that's the way it works here,your location may be different,so check with them.<br>I used a generic hold-down from Checker.I cut a piece of fuel line to insulate the J-bolt that goes between the side terminals,in case the battery did move in the tray,to keep the positive terminal from grounding on the J-bolt.<br>Wherever you get your Optima,you'll love it,they kick ass.Well worth the bucks over a conventional battery. <br>[/quote]<br><br>I also work for Costco, and I second what he says. Costco probably has the best return policy for any retail store, bar-none. <br>Desertrat- did you happen to have either Kevin Bosworth or Andrea Houchins come to your store from Simi CA? Andreas last name may be different now, she went thru a divorce. She works as a cashier, he works in Tires.<br>-Eric
