Painless harness re install
RedBank
Can anyone help with this connection? Installing used painless harness into my current build. Previous install was close to firewall on drivers side. Where can I find the matching male pigtail connector? Or should I splice in and use original connector here?
Sent from my SM-G975U using Tapatalk
Waldo
Which wires go into that pigtail? Each wire should be labeled with a number and name which should help figure out what it is for.
I believe on driver side the pigtails are for either the duraspark ignition or the rear section wiring harness. When I did my initial install, I had to splice all the wires for the Duraspark module.
I have my old painless wiring installation manual if you need further assistance.
Good luck!
