PAINT - D20 color?
chrlsful
I have the '66 - '72 "T" handled Dana 20 transfer case. Thought I'd use the search function here to get a color but was unlucky. I didn't see any specific "paint" forum here either altho I seem 2 remember 1 for it & 'drivelines', 'interior', etc on the site. Must B gettin ol.
Can any 1 tell me a red rattle can code # to repaint my Transfer?
I see
Duplicolor
Rustolium
as 2 of the value (Krylon is too inexpensive) oriented companies I'm willing to use AND that are in local stores.
I went thru this (same 2 companies) w/the touch up for the motor ('60s ford lght blue) & all folks could refer me to was the "Ford Corporate Dark Blue" numbers for Duplicolor. Also same paint code # for cans of companies not avail. round here (& still only in the Drk Blue).
Kinda stuck. B great if U had some numbers for 1 of those 2 co.s ;D
Thnx !
chrlsful
chrlsful
Hey, viper, good 2 C U again.
mine's red, had it frm 1983?
Humm....
How could I cover it, or match what's on it...read the plate & ask Dana Spicer?
sanndmann3
Different companies make cast iron color... really like the end results...
Jluck
Are you looking for historically correct paint color for the same Bronco that you're cutting, welding and mashing axle parts together? If yes press 1....
(1) go buy any old cheap rattle can in a color you like and fog the hell out of it.
If not...
Have it blasted and use a satin clear coat. ;)
Hotrodjohn
when I rebuilt mine I took it down to bare case, sandblasted it, and painted it with satin clear like jluck mentioned above. Keeps the rust away.
darkmagus
Duplicolor cast coat iron would look good on it. It’s what I painted my 8274 with when I rebuilt it.
chrlsful
chrlsful
my goodness the 8274 looks good.
OK, guys, will start w/the red oxide primer...no sand blasting.
May B a lill lght sand/pneume wire brush on the exposed(no red there currently)prts 1st.
Thnx 4 da help 2 all of yous!
(or if frm my Mason/Dixon birth Roots - 'U-all')
chrlsful
chrlsful
Any 1 able, ready and willing to name a rattle can # 60s ford lght blue engine color in the 2 co.s above.
I wuz a prts guy @ AutoZone for a half decade...any of theirs - Advance, O'Ryle's, NAPA (the preferred), Home Depot, Lowes, True Value (Ace Hrdw), Walmart...
I found some specialty paint (spray can) at an auto paint specialist but it was off too.
Don't wanna go to pnume spray (PPP or other) as I have such a sm amount to paint (set up, clean the gun, thin, mix'n measure, etc) just went thru that w/the engine bay (primer, paint).
Thank you again. May U have ease, safety'n hi production w/ur own projects!
Jluck
I got all wild and crazy and went with black.
chrlsful
chrlsful
Kouwell.
Looks like hamertone or sumpin.
Like the intermediate (I used a $28 r. can of clear) is cleared'n transmission is same as D20...
bronkenn
Bronco Guy
Southeast Ohio
I used POR15 cast iron grey detail paint. Very nice product. When you spray it you can tell it is not your hardware kind of paint. Ken
