1972, 302, power steering
My EB has always steered horrible; It appears one of the PO's put f-150 coils under it. I am not sure it has the correct c-bushings and I think the caster is off. It also has a ton of play in the steering wheel. So last night I pulled the tie rod and drag link off. I noticed the studs in the tie-rod ends and drag link end all move about one eighth to a quarter inch, inside the ball. My thoughts are the steering is shot; please confirm…..
Also; with the drag link off, I centered my steering wheel. The pitman arm is not parallel to the frame; instead, the end points out toward the passenger side 23 degrees. Is that right? or should it be parallel with the frame? Sorry for being so wordy
TIA Lou
TIA Lou
