Please explain this tag
And since the seller says "open diff" he either may not know what's inside from not having it apart it looks like, or just as likely the old limited-slip is either gone or worn out so that when he might have tested it by turning the axles, the other one went the opposite direction.
If that's the case, then the unit is well and truly worn out in a big way. The clutches have to get pretty bad before it will act like an open diff on the bench I believe.
Still seems like a lot of money for one, but I don't really know what they go for these days, or how seldom a Bronco housing comes up. A brand new one costs $480 for a super-duper heavy-duty Bronco-specific housing. Without the 3rd member of course.
Hope it's what you need, and nothing is wrong inside.
Luckily you can go look at it before shelling out any money.
Viperwolf1
electron whisperer
WFP-B is also a small bearing, small brake axle.
E
elan
s
Thanks for the opinions lads. What about the 8.7 on the tag. My intel books are not handy, I was always under the impression that early Broncos all had 9 inch rears.
Where am I screwed up here? Wouldn't it read 9.0 on the tag?
Crush
Greenbottom, WV
might be a swapped in axel from a car. like a maverick/mustang II or granada. i think they were about the same width
bmc69
No. "We" refer to them as "9-inch" but that's not something Ford put on any of their tags or in their parts/tech literature. ;)
Viperwolf1
electron whisperer
That is the ring gear diameter in inches. 9" isn't always 9 inches. Lots of variation due to ratios and probably some other factors. It's a stock tag and axle from a '71 Bronco.
jamesroney
Fremont, CA
On the tag it reads 8.7. I think I also read somewhere that same rear end measurement was in Granadas or Mavericks? The explanation seems a little off from the tag. Comments please.
https://sandiego.craigslist.org/esd/pts/d/spring-valley-early-bronco-rear-end/6810990359.html
Regards from,
Scoutingranch
From the Ad:
"Bronco rear end. Bought for hot rod but went a different route. 3.50 gears open carrier. Complete drum to drum. These are one of the narrowest factory 9 inch fords. It is 58" wide."
So this is a:
WFP-B = 1970-73 Bronco, 28 spline, 3.50 Limited Slip
0KB = Assembled 2nd week of October, 1970 for a 1971 Bronco
3L50 = 3.50 ratio, Limited Slip
8.7 = 8-3/4 inch diameter ring gear for a nominal 9 inch housing.
695A = Plant code
Not sure about "narrowest," but it is 58 inches wide from flange to flange, and will have a 5x5.5 semi-float (big pattern, small bearing) axle shaft. 64-66 Mustang is narrower, at 57.375, and 57-59 Ranchero is narrower at 57.25. also 74-77 Maverick at 56.375. Not sure why this is interesting.
The 8.7 represents the ring gear nominal diameter in inches. It's really 8.75, but as stated above...it's a fairly arbitrary measurement. It will bolt on to a 9 inch carrier, and fit into a 9 inch housing. Since "9 inch" is a description, and not a physical dimension, it turns into a name game. The family of 8.75, 9, and 9-3/8 are all interchangeable at some level.
This is not to be confused with the Integral Carrier (non removable) Ford 8.75 rear axle in the 75-76 Grenada (WER-T for example) which is also coded 8.7.
Also not to be confused with the Ford Integral Carrier 8.8 axle.
E
elan
s
Thanks for the break down James. And the rest of youzzz. Again and as always, you guys exceed my expectations. This is one of the best and friendliest vehicle websites as the passion never seems to falter.
