jbrown98604
- Jul 27, 2005
- 21
I bought this bronco about five years ago thinking it only needed a clutch, I have tried several clutches currently running a center force, with a newly resurfaced fly wheel, the bronco shakes when i try to take off. I have put new springs front and rear james duff 3.5", i installed a new motor, different transfer case, transmission, purchased new body mounts, clutch rod adjustable from wild horses, changed clutch push rod and all mounts / rods. I have changed the rear end to big bearing 31 spline and installed factory limited slip third member, bought new drivlines from wild horses. If i pull the front drive line and put it in 4wd it drives fine no shaking. I have also replaced the shackle bushings, motor mounts tranny mounts, is there anything i missed? or any ideas?
