Powder coat 3speed and Dana ?
boogie
Lafayette La
Anyone powder coat the trans and transfer case? I bought a old set to rebuild and thinking about powder coating everything
EricLar80
Did you dig that one out of an estuary? ;) No reason your can't powdercoat it, except you have to make sure all the sand is gone before reassembling it all.
It's just cast iron. It can be powder coated. Watch all the machined surfaces. Take them in as bare cases and LOTS of masking. That much iron will take longer than normal to get up to temp and longer to cool off. Any good powder coater will know that. IF you are trying it at home, it will take a longer bake cycle to really get the iron up to temp.
If it was powdercoated correctly, just put it back together. If it was done wrong, got powder inside or on machined surfaces, get to cleaning or it isn't going together right.
boogie
boogie
Lafayette La
Started in the middle 😂
