This last weekend, I drove my ‘73 EB with Saginaw pump and 1999 Ford Mustang Cobra hydroboost (Cardone 52-7360) out of its relatively warm 40 deg garage, and parked it outside in 15 deg weather for a few hours. When I returned and put it back in the garage, I heard that familiar groan from the power steering that it had air in the system. I perservered and got it parked inside, and sure enough I found later a big puddle of presumed bubbled over power steering fluid (marked with UV dye to find leaks) under the truck. I jacked the front axle up so the right wheel was just barely touching, started the engine and moved the steering wheel a back and forth a bit - no bubbles in the Saginaw pump. Hit the brakes, loud groan, and many, many bublbles.
I’ve never had this kind of issue that cold could cause frothing of the power steering fluid. Does this mean I have a bad seal in the hydroboost, or what?
Thanks.
Thanks.
