Jerrod4567
I went to install my aussie locker today. I Put the thrust washers on the 2 side gears and stuck them in the carrier, then I put the spacers over them like the instructions say to do. After that I drove the pinion shaft in. there is supposed to be .006-.020 play btween the spacers and pinion shaft. Mine has zero. It fits so tight the gears wont even turn. I tried puting it in 3 different carriers all with the same result. Anyone else run into this problem? Thanks.
