But that comes with a caveat.
Definitely take a sample of the materials tou’re going to have on the floor and lay them under the pedal.
Push the pedal all the way and verify that the throttles are wide open.
The caveat is then, how high does the pedal come up to retract? There are many scenarios with Ford Efi where the pedal is far too high in order to get the full travel.
If you then put the pedal where it’s comfortable for your foot, ankle, knee, and hip, then it won’t open the throttle blade all the way.
You might have to mimic the bell crank set up that changes the ratio. Sort of a variable pulley setup.
I think it was Viperwolf1 basically taking a wheel/roller, creating an eccentric, so that the throttle moves slowly at first and then accelerates as you push it past halfway.
This was not primarily for full travel achievement, as much as it was to reduce the instantaneous (over exuberant) lurching during tip-in.
