Project grocery getter
DEEPWOODS
Phil thanks for meeting me in Dothan with the Dana 44 I wish I could move with my build like you. Hell the Dana 44 is still in the back of my truck LOL Thanks Again Keith
P
ponyracer
Crestview, Fl, 32539
Well I've made a "little" progress, sold my wheels/tires, ended up ordering some more
35's for now. Going to run KM2's on an 8" wheel. Made some progress on my fuel tank, got most of my brackets in from ruff stuff and ballistic. Only hold up now is the 1.25 heims from ruffstuff. Gotta have this thing ready to drive to work on monday but I don't know if it's gonna happen!! Heims are supposed to be here thurs/fri, still need to install them and flex everything to see if the arms are going to work, pull them and brace/weld them. Then install the arms and trailer the rig into the ship to use the big mig and burn all the mounts for the leaves and coil buckets, etc in. Haven't even started on installing the hydro boost yet.
Onto the pics....
Arms are 52" with the original front part welded on. Prob going to cut them down to about 48" total.
1 3/8 solid bar trac bar, 36" long
Pretty decent angles on everything, shouldn't get any bumpsteer
My ballistic square tube adapters.
I'm just sitting here watching it rain today, prob try to go buy some bolts and get my tires mounted today but that's about it. Prob finish welding my fuel tank as well.
P
ponyracer
Only thing I'm not real happy about is having to use a dropped pitman arm. Not sure why I need to, the original d44 that was under the truck didn't need one, steering was narrowed f150 stuff, this is full width f150 stuff. I couldn't even get the tie rod into the stock pitman arm due to the steep angle. Guess maybe because it isn't at ride height? I may have to go back to the stock pitman arm and make some adjustments to the track bar.
P
ponyracer
Well she's about ready for her second "maiden" voyage. Got everything welded, she's back rolling again, just have the hydroboost and brake lines to hook up, body bolts, seats, and about a million other little things. Pics up soon.
englewoodcowboy
Lick Creek Restorations
So you are going to Alaska, how are you getting there? Driving from FL or putting it on a boat?
kb6677
Cool build, nice job-saw your post on Moab-we will be there on my "spring break" 4/24-28. What part of Alaska are you heading toward?
P
ponyracer
I'm going to Anchorage by way of a year in korea. Heading up there summer of 2012. I'm hoping I win the lotto so I can go to moab. I've been wanting to go for yrs, by the time I make it they will have closed it and built condo's everywhere.
P
ponyracer
Here's some pics that I've taken over the last couple days. More to follow.
Got the rear discs done, ruffstuff brackets, 89 bronco front rotors, and chebby calipers.
Rear shock hoop, will be tied to the exo when I get my bender.
Will be welding tabs to the leaf spring plate for the lower.
You can also see my homemade fuel tank in the background. I'll get some more pics once it's mounted.
