I replaced my passenger floor, rocker panel, door post, kick panel, and inner fender last fall. And I'll be replacing the driver's side in a few weeks. Yes, mine is a rustbucket. ;D
Cliff's notes version:
Before removing the post, measure the post position in relation to other parts of the truck so you'll know where to reweld it.
It will be difficult to remove just the door post without the rocker but it can be done. You'll pretty much have to cut out the post in big chunks to get down to the remaining bit of metal around the rocker. There are a LOT of spot welds to drill out so buy yourself a good spot weld drill bit. Mcmaster-Carr sells the one I use for about $15. Take your time and go slow and use a wire brush to help you locate the spot welds. There is also a bead weld at the top of the post that needs to be removed. But be careful how you cut this or you'll not have anything to weld back to. Grind all the leftover spot weld material
When installing the new post, only weld the top of the post first, and clamp the rest as much as possible, then reinstall the door to get the positioning exactly right. No matter how well you measured before you took the post off, the door needs to be in there and aligned at the rear of the door to get it right. Dont ask me how I know this, I just do. %) Tack weld the post in place with the door in position, then remove the door and finish welding. A little seam sealer and paint and you're done.
