You should definitely feel an improvement over stock EB manifolds gladrich. And if you're going to eventually do a cam swap anyway, you're going to benefit more from the cam while using headers than with stock manifolds. So it's still a good first move in my opinion.
The cam will likely yield even more of course, but even that gain is enhanced by a better breathing exhaust system every time. And headers free up that initial restriction very nicely.
While you "should" be able to see differences between the two types on a dyno, you might not always feel the difference between shorties and longies by the seat of your pants. You might, but it also might not be that spectacular a difference.
Then again, as Dave said, it's all about the whole setup and how it all works as a "system".
I kind of agree with bronconut about them being just a little better than "good" stock manifolds. But EB's had nothing like good manifolds! Ports were too small, bends were too tight, volume too little as each cylinder empties into it, and the overall size just too restrictive for good breathing. Due, most likely to the low-rpm nature of the expected use of an EB and the relative lack of available space to put them in. Not to mention budget building being what it was, trucks were un-loved cousins to the muscle and luxury cars of the day, so better performance wasn't likely to get costed into a better manifold for the lowly Utility Vehicle.
Most Ford manifolds used similar criteria in there designs I would think. But while some had very good breathing, EB's missed that boat. Look at the stock manifolds on something like a modern GM LS engine though, and you could probably put headers way down on your list of needs.
In other words, replacing stock EB manifolds with either type of header and I think you will feel a difference whichever way you go.
Some additional points to ponder. If you're going to run full dual exhaust down each side, either type is easily utilized. If you're going to run a 2-into-1 system though, the shorties do have an advantage and give you a little more leeway when it comes to choosing the location of your driver's side cross-over.
