Ram assist questions
moeszyslak
I am wanting to see if I can get some pics of a ram assist installed on an early bronco. I purchased the psc kit through wcb4x4.Com.
I am having trouble figuring the best place for the ram to be located. I have a 1.75*8 ram. Thanks in advance.
bigjhoov
nobody
They're typically mounted with the body of the ram attached to the trac bar mount on the axle via tabs. Piston end gets mounted to the tie rod with another set of tabs.
Found a pic in another thread. Search "hydo assist" for more help.
attachment.php
FFMDX
Roseville, CA
This is how my Redneck Ram is mounted (custom mount made out of 1/4" plate). On the axel side, it is mounted where my panhard is mounted and then onto the tie rod. Some people like to mount the body side of the ram on the frame, pushing on the drag link..I'm not a big fan of that set up, mainly because of the potential lateral pressures placed on the frame and drag link/steering box especially when your tire is btwn two rocks and you keep turning the wheel. You cant really "feel" the road/trail as much with the ram; and the pressures created by the ram are pretty high.
Just My $.02
Sean
http://www.norcalbroncos.com/forum/attachment.php?attachmentid=2060&d=1153020504
http://www.norcalbroncos.com/forum/attachment.php?attachmentid=2059&d=1153020504
M
moeszyslak
I am thinking about going from welded cross member directly to pitman arm or drag link. Just looking at these options it looks like I will have some clearance issue
That puts all the stress that the ram + steering box can generate all into the drag link (and depending on steering linkage all through the passenger knuckle).
By mounting to the axle housing and going to the tie rod you are distributing the power steering forces more evenly. Even if all the force is going into a single knuckle it is coming from 2 separate sources. Say everything is going into the driver's knuckle, yes that one rod end takes all the force, but it isn't all going through the passenger knuckle and the drag link as well.
C Saporito
I had a problem fitting the ram with my drag link and steering arm, I used a method similar to what you are talking about.
I have HD hemi connectors, I would not set it up this way with the stock tierod ends and drag link.
One pic shows now, the other is before TRO and dropped track bar mods, but shows the drag link connection.
M
moeszyslak
attachment.php
Does anybody have some close up pics of mounting to trac bar mount. Like I said before I'm concerned about my ram fitting and not hitting anything
It's a legit question moe, but the proof of the final setup is going to be subject to exactly what you have in your kit and how your truck is set up. Not to mention that thing that keeps rearing it's ugly head, that every Bronco is different.
So while the pics might help, the only thing that's going to get you where you need to go with your particular Bronco is to start mocking it up and cycling the steering through it's travel.
As you figured, it's a tight little world down there under the front of an EB. Not a lot of room to add other cool stuff.
But it can be done in most cases luckily, so hopefully yours too.
Got pics of your current setup? Is it all stock linkage? Lifted how much?
M
moeszyslak
No pics right now. It's in pieces.
Lift. 5.5 James duff
Trac bar. Drop bracket on frame
Knuckles. 78 f150 disk brakes
Steering. 1.5 solid chrome moly tie rod. Drag link 1.25 solid bar both with 3/4 hiem joints.
78 f150 steering box
JWMcCrary
This is the same Bronco that Bigjhoov posted. Notice that the tierod is under the knuckle, I could not do TRO and have enough clearance to make it work. The tract bar mount is up 3 inches on the axle using WH riser. I have 2 of them setup exactly like this. The other one is not finished yet but doesn't have any clearance issues. I have seen numerous others setup the same way.
gddyap
Mtn View, CA
I'm going to have to redo mine. I had the body mounted by the axle track bar mount and the shaft mounted to a clamp on the tierod. The ram wasn't parallel to the tierod so as it pushed and pulled it caused the tied rod to roll forward and back. I would need to extend the mounts on the axle.
Also I've read you want both joints on the ram to be mounted in the same plane, ie both bolts vertical or horizontal. If you look at bigjhoov's, the mounting bolt on the axle end is vertical and the bolt on the tierod end is horizontal.
I use the Performance Unlimited steering with heim joints and it looks like bigjhoov's. I'm considering attaching the shaft end of the ram to the driver's knuckle. This may balance things out because the drag link is attached to the passenger knuckle. The body of the ram would be mounted to tabs on a RuffStuff 3/8 diff cover.
chuzie
5.5 James Duff, WH drop and adjustable.
Apogee
Tangent, OR
...Also I've read you want both joints on the ram to be mounted in the same plane, ie both bolts vertical or horizontal. If you look at bigjhoov's, the mounting bolt on the axle end is vertical and the bolt on the tierod end is horizontal...
I've read that too...it was in PSC's installation instructions IIRC. I disagree with that statement though, as it shouldn't matter so long as you don't exceed the range of motion of the spherical rod ends with which you've mounted the cylinder. My brother and I mocked it up both ways on his Toyota and chose to use the out of phase orientation for packaging reasons.
gddyap
Mtn View, CA
I use a Redneck Ram on my 76-77 Dana 44. I measured for the ram travel and had them put in a limiter. It's about 7". So you should measure what your ram travel will be lock-to-lock before you install your 8" ram. You may want to limit its travel.
chuzie
Same here. I had to limit my PSC about an inch. Had an aluminum spacer made for it.
chuzie
Well crap! Wish I had known that. Noted for future reference. Thx
M
moeszyslak
I measured mine stop to stop on the axle. I have 7 7/8 travel . No drag link hooked up. Need to get reassembled. 8" ram so hopefully ill be good.
treihesse
If ypu you do not stroke the ram it will blow out your ball joints. Find your steering stroke ( around7") and have a spacer made to limit it. Stick it up on stands and cycle your suspension left and right for clearance.
treihesse
I put a framing square on the axle to the tie rod made marks on both. Cycle left and right made marks on both then measure it. Limit thay measurement by 1/8
