On a previous thread you guys convinced me to Raptor Liner was the way to go. Well the time has come. I plan to spray this weekend and I'm doing the prep work now.
Full disclosure I'm doing my Samurai this weekend before I do the bed of the Bronco. Like to get the mistakes over and done with and technique down before doing my baby.
All rust has been removed I.E. cut out and replaced with new metal.
Any surface rust has been hit with a power stripper and coated with POR-15
All newly welded in metal has been cleaned and POR-15'd
Everything that can be removed has been.
Plan is to start roughing up the paint tonight and wipe it all down. Use some self etching primer where needed and once dry, rough it up with 120 grit then clean everything one last time. Seam seal some areas that need it.
Tape everything off and spray on Saturday (maybe Sunday if I get behind)
Any "gotchas" I need to worry about? Masking advice on the bed rails and around the doors?
Tim
Tim
