Rear axle replacement question
Beau Nugget
NE Kansas
I’m replacing the rear axles in my ‘75. My question is when I install the new axle/wheel bearing assembly, would it be a good idea to put some green loctite on the outside mating surface of the sealed ball bearing to hold in place better? Or is the loctite unnecessary overkill that will just make disassembly more difficult in the future? The old axle bearing hasn’t been run to the point of complete failure, and chewed up the inside of the axle tube. Thanks
For me, it pretty much depends on how it goes together.
If it needs it, use it. If it doesn’t need it, don’t.
They usually don’t…
Are you using standard sealed ball bearings, or the heavy duty Set-20 tapered rollers?
Beau Nugget
Beau Nugget
NE Kansas
They usually don’t…
Just the standards. They’re wild horses 8654 and 8656 axle assemblies. I think I’ll try it without You have to give it a bit of a shove to seat the bearing in place. I bet it’ll be fine without.
73azbronco
if you had to press it on, it won't be spinning unless seized, another issue.
bigmuddy
Marthasville Missouri
If I am understanding your question correctly? I had to use some great stuff sealant on my 77 axle years ago because I couldn't keep it from weeping lube. Hasn't been an issue to pull or replace but I always put a small amount on to keep it from leaking. This again was due to some pitting I beleive.
Johnnyb
Flagstaff
So if I'm recalling correctly, the old school Ford bearings required a grease seal inboard of the bearing. The improved bearings that you get with the wild horses axles and probably others have the grease seal Incorporated with the bearing. In light of that a bead of RTV might be a good idea?
Do NOT loctite the bearing to the housing.
Bearing to the shaft, could care less. There will be presses and/or destruction of the bearing to get that off anyway.
We sell both types, so it matters specifically.
If you have standard replacement 28 spline axles from us, they come with original style, sealed ball bearings. Those use the axle seal pressed into the housing.
If you have the 31 spline axles, they come with the set 20 tapered roller bearings. Those require that you leave the seal out of the housing.
And yes, in some cases, adding a little sealant around the perimeter helps the rubber seal that’s integrated into the bearing race.
It shouldn’t need to, and as far as I know, Ford never did it from the factory. But that’s when the seal surfaces were pristine and new, and that might be the reason that so many of them leak after installation nowadays. The seal surfaces are no longer pristine and new.
Johnnyb
Flagstaff
I appreciate the improvement in design with the tapered bearings - this alone was worth upgrading to 31 spline axles.
Beau Nugget
Beau Nugget
NE Kansas
I was only curious about using the Loctite in order to prevent the sealed ball bearing outer race from turning in the axle tube. It doesn’t sound like that’s like likely to be a problem, so I did not use loctite.
When upgrading from the 28 spline to 31 spline axle shafts what needs to be done to the third member in order to accept that new shaft? Does it require a complete replacement of the third member or is there a modification that is made to it?
gr8scott
You would need a carrier that excepts 31 spline axles, something like this.
The least expensive, and used to be the easiest, would just be to replace the side gears from 28 spline version to the 31 spline versions.
They were available from the factory that way on full-size trucks, so the parts were pretty prevalent for both the limited slip and the standard open differentials. A lot of shops used to keep them in stock.
Nowadays, however, you might not find them as easily and as more and more differentials, simply age out completely, more and more people are simply replacing the entire original differential carrier with something like a true track or similar.
Beau Nugget
Beau Nugget
NE Kansas
Thanks gr8scott and dirtdonk. I assumed there was a way to convert it to 31 spline, but, yeah, it seems like replacing the differential would be the way to go. That way if you haven’t owned the truck very long, like me, at least you know what you have.
