Rear Output seal
kip60
Anybody out there replaced the seals on the transfer case? I've done the front output shaft and was looking at doing the rear next. Took the bearing retainer off the front and did everything off vehicle. Truthfully I tried to pull seal while it was on and mangled it but still couldn't get it out. Can the rear bearing retainer be taken off without taking the shaft with it? The front stayed in place with no issues. Don't really want to get too deep in this if I don't have to. I see on the diagrams that there are needle bearings on the other end of the shaft, so I don't want to disturb anything. Thanks for the help. It's a 70 with stock d 20 with no upgrades.
Glass Pony
Sussex County Delaware
You "may" be able to just pull the seal without pulling the rear out put assembly but if things go south it isn't hard to do. Just keep track of the 13 roller (needle) bearings and have a new gasket ready.
I know what you went through on the front as I just did that job also. I've worked as a mechanic in the power generation field for over 30 years, done plenty of lip seals in pumps and gearboxes, and I've never seen one so stubborn. I tried using a slide hammer under the bronco and couldn't budge it. Removed the retainer and put it on a vise on the workbench, using a 2 lb. ballpeen and 3/8" punch to drive it out, the punch would rip through the steel of the seal. After a while it finally came out.
Not a big deal but I had to wait a few days for a new retainer gasket as I didn't have one handy.
If you do pull the rear output assembly when you remove it hold the yoke end a little lower so the rollers don't dump inside the transfer case.
If it's got to be done, dive in and good luck!
BTW I got a D20 gasket set from Rock Auto for under $10 shipped to my door.
bax
Old Member
Yes you can change the seal without removing the rear output. Take the yoke off and pry the seal out. Seal puller will help.
kip60
kip60
Thanks guys. Pony, I got the same gasket set from Rock Auto ready to go just in case, but really don't want to mess with those roller bearings if I don't have to. Wondering if the rear was the same as the front as far as trying to get it out.
Glass Pony
The rear output seal is the same but you don't have the luxury of just pulling the retainer if the removal of the seal goes bad.
The worst thing that could happen is a roller could drop in the case while pulling the rear output assembly. Then you may have to pull the inspection cover to retrieve it. The good news is if you have the gasket set, you have the inspection cover gasket also.:) This may also be a good time to replace the o-ring on the speedo cable while you have it out.
When reassembling, use a little Vaseline or assembly lube to hold the rollers in place while you install the output assembly onto the transfer case.
It's a few more steps but doable.
My motto is "I can screw it up just as good as anybody".;)
kip60
kip60
Thanks for all your input. I did get the seal out without having to resort to taking off the bearing retainer. Got everything cleaned up and so far no leaks!
