Rear yoke size?
eds66bronco
Essex, Vermont
what is the correct yoke size for a 9" rear-1310 or 1330? mine is leaking pretty bad and grooved around the seal area. i have another yoke that looks like it was ready-sleaved. anyone done that or have a part number to do it?
thx
ed
bmc69
CR SpeediSleeve part numbers are easy to figure out just by the diameter of the seal surface. PN is 99xxx, where 'xxx' is the shaft OD. For example, you want to repair a 2.5" OD shaft, its a 99250, 2.25" is 99225 and so on.
SaddleUp
Vancouver, WA
1310 (Small) - 1.0625" Cap, 3.2188" across
1310 (Large) - 1.125" Cap, 3.2188" across (This is what the EB and 76-78 Full Size uses)
1330 (Small) - 1.0625" Cap, 3.625" across
1330 (Large) - 1.125" Cap, 3.625" across (This is what the 79 Bronco/Full Size uses)
1350 - 1.188" Cap, 3.625" across
1410 - 1.188" Cap, 4.188" across
eds66bronco
eds66bronco
Essex, Vermont
thanks for the info guys. i'm going to try and sleeve it first. at least if it doesn't stop the leak, i'll have a trail spare.
