Reasons to go 44?
wheelsblank27
I have been saving money for a d44 swap in my 68. I sometimes drive m brothers 73 w a 44 and although I do like some things about it I really don't like dealing w ball joints and alignment,They wear out fast around here being a drier climate and disintegrate in a couple years. I have never broken an axle and rarely see mud deeper than say2ft. Basically I like to go fast and get sideways on gravel roads that lead me to far off natural hot springs w my two boys and wifee. I am thinking about installing a Aussie locker on the front and building my rear end some... Get a big bearing axle 11pack 3.5 leaf pack and some good shocks on all 4 corners. I think I can do all that for the price of a d44 w Chevy disks. Does anyone run this setup and like it? I know almost everyone likes the d44 but most are using their trucks for different reasons
My reason to go to a 44 was the 30 went boom with how I was using it. 44 was to prevent that from happening again. If the 30 works, it works.
Never had a ball joint wear issue, and ball joints are a lot cheaper to replace then rebuilding the D30 kingpins.
W
wheelsblank27
Ok, how did it happen? We're you flooring it up a slick rock? Or just drivin along? What was goin on when it happened? Did you replace pins ever? I'm just trying to judge my best interests, sorry for the stupid q's
broncnaz
Main reason to swap is usually tire size your breaking stuff now and want to add a locker. I dont see where ball joints or alignment are a issue as the D30 has the same aligmment adjustments as a d44. I've never had a issue with ball joints either.
So basically if you want to add a locker your D30 starts to become a weak point fast especailly if running tires over 33in. With a locker in the mix I would really consider going with the D44 there are more upgrades availible for the 44 than there are for the 30.
On the other hand there are guys running 35in tires and D30's without issues just have to be careful when your on the gas pedal. Of course these guys are the exception not the rule but it can be done.
AZ69EB
I have a D44 with Chevy disks and Aussie locker with 4.88 gears with chromo axles. The Aussie works great. I think it is the best lunch box locker available. If you go this route buy a new D44 carrier as this will become the weak link in this setup. Plus, they are cheap. Solid set up for your basic offroading.
But, I would wait until your D30 goes boom. It will if you play hard.
Airborne69
Moorpark, CA
Your style of wheeling sounds very similar to what I like to do. You are going to have problems mostly when going airborne (front end or all 4). If you don't get off the gas pedal in time, when you come back down there is a large potential for breaking things. I have a video, from back in the 80's, of my dad racing my bronco. He came around a turn pretty hard, hit a root which sent it up on two wheels. When he landed the rear driveshaft snapped and sent him off a different direction. Upon backing up and mashing the gas to get back on track, he took off every tooth from the front ring and pinion and shattered the locker. 20 years later when I opened up the diff, I got a handful or two of metal chunks and shavings. I can email the video to any contributor who would be willing to post it.
I personally would wait until the D30 blows, but if you do get caught in a situation where you lose power to the rear end, I would trust a D44 much more for limping home.
bknbronco
North Metro, MN
i rebuilt the king pins, and drum brakes on my 30 and will run it for many many years hopefully. I have a 44 and the ford disk brake stuff in my basement but to completly assemble that axle as well as change gearing im thinking would run around $2000.00 and thats with a open dif! Im actually hoping to wheel the bronco in the next couple years and im sure the 30 will hold up just fine. My dad and my bro have wheeler there jeep cherokees for lots of years on lots of trails around the country and all they ever had were 30's in the front. Of course there more fenese drivers instead of gas pedal mashing drivers you often see breaking shit in the woods!
When i do build the 44 its gona be shaved and plated and beefed up!
May i ask why the need for any sort of locker in the front??? Of all the hundreds of trails and jambores my parents and bro have been to they have never had lockers (front or rear) until last spring. My bro added a lunchbox locker to the rear and my parents now have a new rubicon with front and rear selectable lockers. The only reason they have lockers is so the cant be denied access to the hardest trails on jamborees, and they both added winches for the same reason. they have both been on trails since and my dad never turns the lockers on and neither have yet to use there winch.
Moral of the story is.....you really dont need lockers, espically in the front. The rear locker can actually be a pain in the ass on the street! I have seen unlocked trucks get past places where locked trucks just broke apart!
Pokey71
That aussie locker will snap an axle shaft real quick in a 30
I was at idle, hung up on a rock. With the 435 in granny, low range and 4.10 gears. Half throttle on the 351 holding it back with the brakes trying to get the limited slip to bite. It bite, locked into a spool and I drove off the rock. Then all the teeth got in the way of the other teeth and popped or cracked 40 of the 41 teeth on the ring gear. Stripped one side gear smooth, the other had 2½ teeth left on it. When I backed it into the garage to figure out why I only had 3 wheel drive at the cinders I noticed severe camber on one front wheel, all the little bits in the top of one of the king pins had come out. I knew what I really wanted to do so I get a locked D44 with 4.88 gears. Stock axles lasted a few hours until I popped a U-joint (at full steering lock spinning the tires in reverse pivoting on the rear bumper corner backing up a solid rock waterfall). After that I upgradded to full size U-joonts and it lived until I did something stupid and put a cheap parts store U-joint in the front axle (after taking the shaft apart to do a little investigation for an hair brain mod and loosing the needle bearings for the good Spicer joint)
so 2 of the 3 failures I will attribute to insuficient strength of parts, third was my fault for cheaping out in getting the right part and just getting "something to get me by until I get the right part". Actually #2 was a known weak point but I had the shafts in hand and was broke from doing the rest of the upgrades. So I just ran the it and got a little life out of it until I was quickly forced into an upgrade.
The 30 is known for sheeding teeth backed up with axles that snap. The rest is pretty good. Some of the old baja races show the long side axle tube pulled out of the center section but I will atribute that mostly to jumping and general off-road racing.
broncnaz
Back in the day tires were not all that big L78-15 was about as big as you could get and they were only about a 30in tire
W
wheelsblank27
Lots of good info here, I am finally getting some real case scenarios and reasons to upgrade. I am still up in the air though somewhat. I def. don't want to get stranded on some of the roads I travel because they are so desolate I don't think cell phones work so no calling tow truck. And I could see myself breaking an axle or a u joint (axle) if I used the cheaper ones.
1. Do they sell stronger axles for the 30? More splines?
2.whaneither parts will I need to install bigger axles?
If I can get away w beefing up my 30 I'll just do that, if not than a 44 is what I need
Can't beef a D30. The weak link isn't the axles, it is the size of the ring gear and the teeth that come off it when under load. The way to beef that part is to use a D44 center section. At one point Ford did use a few D44 axles with D30 outers. Yes, there are a few DSO and warranty replacment king pinned D44 axles out there.
W
wheelsblank27
Ahhhhhhhh, so I can swap in a d44 ring and pinion then? Is that what it's called... The gears right?
W
wheelsblank27
Or the whole center section and somehow get the tubes out? I would think if it's just e gears it will be cheap but if it involved pressing out tubes and such it adds up and won't be cost effective? Or am I way off here... Take it easy on me:~<
broncosbybart
The D30 and D44 axle housings are totally different. For gravel roads, do you really need 4wd? I wouldn't think so. That said, I wouldn't plan on beefing stuff up. You'll get your confidence above where it should be. The 9" rear is pretty stout and you will certainly explode the D30 with a locker and a heavy right foot.
I've broken plenty of parts in a D44 w/33" tires. It all depends on how you use what you have.
All that said, if you want to beef the truck up for harder use, the 44 would be the most logical action while doing all the rest.
Jdgephar
Only reason I went Dana 44 was to get the Ford disc brakes. I happened to find a local Bronco D44 drum front end for $100 complete. Got the disk parts, cleaned it up and bolted it on. I guess I wanted the piece of mind of having the stronger axle, plus now I have the good disc brakes.
W
wheelsblank27
I should also mention the squirrel inside my 30.. At least that's where I am 99% sure that's where he lives. I've swapped my np435 for an auto so I know it's not my throwout bearing.. And when I hang out the door driving down the road I've narrowed it down to the front axle.
. So I've got to rebuild this thing, it's probably the u joints on the axle and I don't want to put a bunch of $ into it if I'm gonna upgrade to a 44 later
W
wheelsblank27
He only comes out during decel in third and second gear... I've seriously dedicated a lot of time and $ gettin it to the point I'm at now and ready to get rid of him for good
