Welcome to classic then! I usually catch that, but from my phone can't see anyone's join date. Or at least I have not figured it out yet.
Just realized that my reply was to the very same question by a member of another forum! Interesting and it sounds like Centech recently got away from their original fusible-link protection and is going with the more popular (and easy to fix!) Maxi-Fuse protection.
Before I forget, for this protection you can get away with as little as 40 or 45 amp rated fuses, but you would not be overkilling it if you went straight to 60a instead. Keep a few spares along with your other mini-fuses for the main panel (I like "blow-n-blow" types with the indicator) in your glovebox and you're good for the duration. Because this is the main charging circuit as well as the main power to the cabin and the rest of the truck when the engine is not running, you can go up to the limit of your alternator. So if you have a 75a alternator for example, you would go with maybe an 80a fuse if they make them that large.
Painless used to include a 60a with theirs, but I believe went to a 70 or 75 amp later. They were also talking about changing the main fuse entirely, to a Midi-Fuse and holder instead of the more compact Maxi. I like them both.
If you are updating to an alternator of over 95a rating though, you can go back to a lower rated fuse to protect the main circuit and leave some headroom because you're not going to be using this wire to charge the battery anymore. With something like a 130a Ford 3G alternator upgrade, you'd be charging the battery directly, eliminating the Yellow alternator wire and using the Red wire to power only for powering the accessories.
I'll have to get ahold of some of the current instructions to see what they say. Maybe they did not even update them yet and just let the installer deal with it.
But I would have to say that my previous comment about it being for protecting the main power circuit (10ga Red wire) that attaches to the starter relay/solenoid on the fender still holds until someone else says differently.
Just cut the Red wire in such a way that it leaves you with a short section that you would use to connect between the battery side of the starter relay and the one side of the Maxi-Fuse, then the other side of the fuse gets the rest of the Red wire.
Clear as mud yet?
