- Jun 8, 2010
- 2,213
So we got Dad's 5.0 buttoned up yesterday in between a few other more important projects. We fired it up and it sounded great. However, we ran into problems.
We pulled the SPOUT and set the timing at 10 BTDC. Shut it off, replaced the SPOUT, fired it back up. Now, it idles at about 20 btdc, but retards on revving.
I came here, researched, found that we had constant 12v start condition on the TFI. We fixed that, but in the meantime, I had made some other changes and had left the connection off the MAF and we tried to crank the engine without it three times. It cranks and runs for about four seconds and dies.
Hooked the MAF back up, started the engine with 12V only on start, and now it idles rough, timing now sits at 20 without SPOUT and does not advance...
1. Could the TFI be damaged causing timing and spark problems like we're having?
2. Could the system be screwed up seriously because I left the MAF sensor unplugged and started it three times?
Hope to hear from some folks soon!
Could the constant 12V to the TFI have damaged the TFI?
