Thank guys, I appreciate all the insight and pearls of wisdom. Here is the reason why I asked in the first place. The 351 rebuild might come in stages, that is the 302 in the '69 I'm getting is still fairly strong but I COULD put the new cam in the 302 until I was ready to pull it, then just pull the 351 cam and lifters, keep lifters in order, new cam bearings in the 351 and I could "in theory" get two uses out of it. So, having said that, what about this comp cam for both a 302 and 351
Comp. Cam # CL35-238
Advertised duration 262/270
Lift .493/.500
I can give other numbers if it helps you understand what I'm looking at.
I'm trying to get away with not purchasing two camshaft within a year,,,,
Thanks!
Mike
