A friend has a 72 with 33's and 1" body lift that his wife refuses to drive because the steering is too sensitive. He says he can turn the steering wheel lock to lock with one finger.
I am guessing that the pressure from the pump is too high. I had his pump apart years ago. At the time of installation it had a piston, the one that is just forward of the high pressure hose connection, with a .100" dia. bypass?? hole in the center of it. I measured the hole dia with the shank end of a numbered drill. Does the hole control the high pressure in the PS system? In my yard shopping days I grabbed several pistons with various diameter holes in the center and the springs to go with them. The springs appeared to be the same but I had no way of checking them or pressure gauges to check the system with the engine running.
Are the pistons in the Saginaw pumps interchangeable? Are they fitted or ground lapped to fit the pump body? What size by pass hole will work best with a near stock Bronco?
