scary experience!!
aliensecretion
aliensecretion
Just left 2 different parts stores and can't find 50, 90 or the redline oil. Is the royal purple a safe alternative? Or any other brands?
Thanks for the info on the front too. Considering nothing in the back looked too bad, I'll be checking that out after I get the back end together.
broncnaz
Royal purple is fine if you want to pay the price. look for any gear oil basically 75W-140 donest have to be straight 90W oil heck even walmart carrys gear oil.
Exactly. The 50wt racing oil is getting pretty hard to come by from all reports recently, but 90wt or the 75w/90 should be just about anywhere. It's not so much the brand, as the weight. I just happen to use Redline, but you can find Mobil 1, Royal Purple, Valvoline, Castrol, or just about any brand in those ranges.
And although I wouldn't go all the way to 140 in the t-case or the trans, it's a perfectly legit weight in the diffs. Or even in the trans in the hotter weather or under constant heavy loading.
In my neck of the woods though, seems that the 75w/90 is one of the most readily available nowadays. And happens to be a good fit for your EB's
aliensecretion
aliensecretion
Thanks for all the help guys. Got everything done and went over everything else closely so if it happens again, it's definitely not the rear end! I'm going to get some bushings on order for the front since i've been meaning to do that anyway. This makes a good excuse!
aliensecretion
aliensecretion
Well it did it again on another pot hole. Bushing kit should be here Wednesday so I'll be doing that next. At least I don't feel like I wasted any effort on the back end even though it didn't solve the problem... Just spent the few dollars before I wanted to!
aliensecretion
aliensecretion
So i'm in the garage all set up to replace the bushings but this is the first time i've ever messed with coil springs. Any other tips so i don't kill myself!
Trapperbob10
Follow the instructions provided for C bushing replacement. Make sure truck is well supported under axel tubes with jack stands, and also have jacksands under the frame rails.
Make sure all weight is off of springs and you shouldnt have any problems. Not sayin its easy if you have never removed, just not all that dangerous.
Trap
trailpsycho
The 9" should be 9 pints or 4.5 QTS, not 5 pints. The front end may be 5 pints, but the rear end is ~4.5 quarts. Dont venture too far until you get it filled up or you will be replacing your bearings again.
allenfahey
First I would soak everything with penatrating oil. I would get 4 exhaust studs in place of bolts for the lower coil spring retainers. It will be ALOT easier to line up the radius arm and two spring retainers. Also get 2 longer bolts for the "C" cups on the axle. The new urethane "C" bushings will be hard to start the bolts. Use one in the upper and one in the opposite lower and tighten till you can start the stock bolts you removed. Then remove them and use them the same way for the other side. I'm not sure what size or thread count on neither the retainers or the radius arm but both will save you a ton of frustration.
aliensecretion
aliensecretion
Finished all the front end stuff and getting the tires put back on today. Never did get the radius arms to line up exactly when I rotated them down. No matter what I did it the right arm was always 1/4" higher than the other. Everything else went easily enough thanks to all the good info on here. Spent most my time cleaning gunk off and putting some POR15 down.
Took it for a test drive and didn't get any death wobble but I didn't push it too hard since the new adjustable tie rods and track arm aren't dialed in yet. So here's my last question (hopefully!), my axle is sitting a little off to one side so what's the easiest way to adjust that? Do I just lift the axle, pop the top end of the track arm out, adjust it a little, reinstall and drop it back down?
BTW, ended up with WH springs... really liking them so far!
